Field calculator to update a field using another field in attribute table
4321
11
10-09-2017 09:41 AM
DuminduJayasekera
I have the following attribute table. I need to update the fields using the field calculator (SEC, TOWN, RANG) by using the "mtrs" and "label" columns(fields) in the attribute table.
SEC: (letter S + label)   TOWN: (string from mtrs)    RANGE (string from mtrs)      S_R_T (join the SEC+TOWN+RANG)
S24                               T1N                                     R14W                                      S24-T1N-R14W
S4                                 T1N                                     R14W                                      S24-T1N-R14W
S34                               T2S                                     R8W                                        S34-T2S-R8W
Can somebody help me to achieve this using the "Field Calculator" and Python parser functions?
Thanks a lot in advance.
DanPatterson_Retired
ahhh... slicing again
x = 'abcdefghi__13E'  # ---- since you didn't include an example ----
"R{}{}".format(int(x[11:13]), x[13])  # x = !mtrs!
'R13E'
"{}-{}-{}".format(!A!, !B!, !C!)
just replace A, B and C with your field names but keep the ! ! marks around them.
Obviously , this has to go into a text field and you have to specify python as the o\parserf
table is hard to read, but I suspect that you are also having trouble with the other bits, like getting the SEC field which would be
sectn = '024'
"S{}".format(int(sectn))  # in field calculator  !sectn! with python parser
or are those ok... it isn't clear whether you need the whole process completed, just some bits, or all the work?  And how much python do you know?
DuminduJayasekera
Thanks Dan. Yes I figured and it worked. I am a beginner to Python.
Did you find an alternate solution or do you want to close the thread?
DuminduJayasekera
Apologies for the late reply. Your answers were very helpful. Is there a way I can extract RANGE using the "mtrs" column?
Yes... what have you tried and what should it look like?
This type of functionality is simply python string slicing
other functions string functions
DuminduJayasekera
I used
"R{}".format(int(!mtrs![11:13])) but I am not able to get the East "E" or "W" letter attached like R1E or R18W.
'R13E'
DuminduJayasekera
You are genius. I got the trick now. Thanks a bunch.
