Upload KML file programmatically
4173
10-08-2017 12:32 PM
OnoCrack
I'm trying to use the arcgis rest api to upload kml file to the portal. I made addItem request and then addPart request to upload the file itself. The documentation does not mention how to send the file, so I read the content of the file as text and send it but I'm getting Internal Server Error response.
Here is my code (I also added the js file as attachment):
// get list of files
var files = this.fileSelect.files;
// continue only if the user select one (or more) files
if (files.length > 0) {
   this.uploadButton.innerHTML = "Uploading..";
   var file = files[0];
   fetch('https://www.arcgis.com/sharing/rest/content/users/*****/addItem', {
      method: 'post',
      headers: {
         'Content-Type': 'application/x-www-form-urlencoded;charset=UTF-8'
      body: 'token='+encodeURIComponent(token)+'&f=json&title='+encodeURIComponent(file.name)+'&type=KML&filename='+encodeURIComponent(file.name)+'&multipart='+encodeURIComponent(true)
   .then(res => res.json())
   .then(res => {
      return new Promise(resolve => {
         var id = res.id;
         var fileReader = new FileReader();
         // when finish to read the file, make request with the content of the file
         fileReader.onload = (e) => {
            let data = e.target.result;
            fetch('https://www.arcgis.com/sharing/rest/content/users/****/items/'+id+'/addPart', {
               method: 'post',
               headers: {
               body: 'token='+token+'&f=json&partNum=1&file='+encodeURIComponent(data)
            .then(res => resolve(res));
         // read file content
         fileReader.readAsText(file);
   .then(res => {
      console.log(res); // THIS LINE LOGS "500 - INTERNAL SERVER ERROR..."
      if (res.success) {
         return fetch('https://www.arcgis.com/sharing/rest/content/users/*****/items/'+id+'/commit', {
            method: 'post',
      } else {
         return null; // ...THEN GOES HERE
   .then(res => {
      if (res) {
         return res.json();
      } else {
         return undefined; // ...AND THEN RETURN UNDEFINED!
   .then(res => {
      console.log(res);
Could someone please explain how to upload small file (kml, less than 5mb) to the portal using arcgis rest api (javascript)?
Thank you!
p.s sorry if I have grammar mistakes (I'm not native english speaker) ..
ThomasSolow
In my experience the best way to approach this is to manually add the KML as a portal item using the Add Item option from My Contents and use your browser's dev tools to look at the request that gets sent (chrome has a preserve log option to make sure the network log keeps the request).  You can use this request as a template for what your request has to do.
That aside, here's some code I've used to upload to upload files as portal items using esri/request:
// user is a portalUser.
// fileList is an array of files.
// tags is an array of strings
function addFileaAsPortalItem(user, fileList, tags){
  const file = fileList[0];
  let form = new FormData();
  form.append('file',file);
  form.append("f", "json");
  form.append("title", file.name);
  form.append("name", file.name);
  form.append("type",'KML');
  form.append("token", <server token>);
  form.append("filename", file.name);
  form.append("tags", tags.join());
  return esriRequest(`${user.userContentUrl}/addItem`,{
    method: 'post',
    query: form
I'm not sure if this will fail when the file is too large.  I've used it to upload images, kml, text documents, and more.  It also may be a good idea to use esri/request for this, as opposed to the fetch api.
ThomasSolow
    method: 'post',
    query: form
OnoCrack
That's working. Thanks!
