ApplicationIntent=Readonly not working with Map Service
1499
10-04-2017 06:29 AM
KevinDunlop
We have a geodatabase (10.4.1) that is stored in an AlwaysOn cluster in SQL Server 2016.  Since most of our traffic on the database is from the web and is readonly, I have configured the database to use readonly routing so that readonly connections go to the secondary replica.  I have specified in my SDE connections the listener name and the ApplicationIntent=Readonly.  In Arcmap, the connection is correctly sent to the secondary node, but when I publish the map to Server, it always sends it to the primary node.  I have checked the data stores, and they are set correctly to use ApplicationIntent=Readonly.
Why is ArcGIS Server not honoring the application intent while ArcMap is?  How do I fix this?
Kevin
ThomasColson
Did this ever get answered? We're looking to deploy to HA groups and SQL, and this looks like quite a barrier to that working.
