Summarize Within: Two Input Layers?
4637
10-02-2017 01:49 PM
MarcusVowell
I have a polygon layer of the states as well as a polygon layer of block groups tiered by population density.  I also have a polyline layer representing fiber optic cable.  What I'm wanting to produce is a summary report that tells me how much cable is in each population density tier in each state.  This would seem to necessitate two input polygon layers (state, block groups), which I don't believe is possible with the Summary Within function.
I suppose I could append a field onto the polyline layer that contained the state information, and then just summarize by block group from there, but that seems like an inelegant and excessively manual way of getting these results.  Does anyone have a suggestion as to how this might be done more efficiently?
Thanks so much!
DanPatterson_Retired
It is going to be a 2 step process since you have a polyline layer mixed with 2 polygon layers.  Because of this, you would only be able to get a polyline layer if you combined (via many of the overlay tools).  So basically what you want is a union of all 3 layers... which isn't possible, so union or intersect the two polygons, then summarize the polylines with respect to the resultant
addendum
you can also do spatial joins of various forms, save the resultant, then summarize as well.  Whatever... still 2 step if you want a polygon as the resultant and a table for join-back
addendum
MarcusVowell
Thank you so much for this.  This is exactly what I did and I got the result I was looking for.
glad it worked
