Simple Filter Widget?
1520
09-27-2017 11:06 AM
MatthewJones
I am looking for a widget that would run a simple filter in just one click. The existing filter widget does work, but it requires more steps than Joe Public is going to do. Here is an example of what im after (Find Trails). This is a simple map showing the location of trails in SC. The end user can click on the type of trail they want like hiking, biking, ATV and the map updates accordingly. I assume there would be an attribute filter in the back end or it could turn on and off different layers.
RobertScheitlin__GISP
Matthew,
  Nothing exists that is one click like that. It would have to be a custom widget that you or someone builds or you can use the Query widget with predefined queries that do not have any ask for values.
MatthewJones
Thanks Robert, I actually found one of your tools that I think will do the trick. im going to give it a try. Thanks for all you do!
https://community.esri.com/docs/DOC-8592-layer-toggle-button-widget-version-22-01132017
No problem.
