insert HTML code in Object Literals attribute
2073
5
09-27-2017 06:56 AM
SaraEL_MALKI
Hi guys,
I am working on a  dojo Chart, I wanna turn all the X-axis text to buttons, that I can click them later on,
var circuits_1_=[];
for (var i = 0, len = FeaturesCC.length; i < len; i++) {
var circuit_1_={};
var FeatureCC = FeaturesCC[i];
id_circuit_array.push(FeatureCC.attributes['objectid']);
//var s = '<button id="myDivButton'+i+'">'+FeatureCC.attributes['layer']+'</button>';
//var x = document.createElement("BUTTON");
//var t = document.createTextNode(""+FeatureCC.attributes['layer']);
//x.appendChild(t);
circuit_1_={value:i+1, text:""+FeatureCC.attributes['layer']};
circuits_1_.push(circuit_1_);
I have tried this :
circuit_1_={value:i+1, text:"<button id='smth"+i+"' type='button'>"+FeatureCC.attributes['layer']+"</button>"};
but it doesn't work, HELP me please
Robert Scheitlin, GISP‌ Thomas Solow rastrauch
RobertScheitlin__GISP
Sara,
    That will not work and I am not aware of any way to accomplish that.
Sara,
SaraEL_MALKI
Okay sir, I think that I will go for another charting library, what do you suggest me ?
Sara,
   I don't do much with charting but this is what Google returns:
20 best JavaScript charting libraries
SaraEL_MALKI
Thank you sir for your time and your help
JohnGrayson
Esri Alum
Below is some code I pulled out of an old demo that does what you need.  The task involves two steps.  The first one is to augment the label nodes with a custom inner node (chartLabel) with custom attribute (date).  The second step is to find them and add a 'click' event handler to those nodes AFTER they've been rendered.
// GET CHART LABELS //
getChartLabels: function (store) {
  // CHART LABELS //
  return store.query().map(lang.hitch(this, function (item, itemIdx) {
    var selectionClass = (itemIdx === 0) ? ".chartlabelselected" : "";
    var labelNode = put(lang.replace("chartLabel span{0}[date='{1}']<", [selectionClass, item.monthDate.valueOf()]), item.text);
    return {
     text: has("ie") ? item.text : labelNode.outerHTML,
     value: (itemIdx + 1)
// CUSTOM AXIS LABEL BEHAVIOR //
aspect.after(this.monthlyChart, "render", lang.hitch(this, function (evt) {
  // ALLOW USERS TO CLICK ON DATE CHART LABEL TO SET MAP TIME EXTENT //
  query("chartLabel", this.monthlyChart.domNode).forEach(lang.hitch(this, function (node) {
    node.innerHTML = node.innerHTML.replace(/ /g, " ");
    on(node, "click", lang.hitch(this, function (evt) {
      var dateValue = domAttr.get(node.firstChild, "date");
      this.selectMonth(this.monthlyTotalsStore.get(dateValue));
}), true);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I hope this helps.
