Truncate String - Remove Space
8307
17
09-26-2017 11:41 AM
by Anonymous User
Not applicable
I'm trying to implement a truncation in my script, which is easy enough, but I need to make the overall script smart enough to remove the last character if it happens to be a space.
For instance, if I have the following code:
  1. variable = "SAMPLE NAME"
    truncVar = variable[:7]‍‍‍‍‍‍‍‍
This ends up returning "SAMPLE ", which is right, but there's a space at the end of the string.  I need the script to check for that space, and delete it if it's there, otherwise leave the last character.  I can't just reduce the truncated value since the actual names in the variables will vary widely.
Thanks!
Working Script based on correct answer:
variable = "This is a test variable"
trunc = variable[:10].strip()
result = "'" + trunc + "'"
print result
'This is a' # The strip operation removed the ending space, but it left all others
MitchHolley1
Look into strip().  If you don't pass any parameters, the function will remove spaces before and after a string.  I don't know if that will help or not.
JamesCrandall
I'd think split() is a better method as long as the space between the two words is how you identify what to evaluate.  That way it doesn't have to be a set number of characters to the left or right.
splitVar1 = variable.split()
print splitVar1[0]
by Anonymous User
Not applicable
I should have expanded a bit more. There is a potential that there could be a space somewhere before the truncated number of characters.
So instead of "Sample_Name" with only one space, we could potentially have "Sam_ple_Name" with two spaces.  In the second instance, I need to only remove the last space.
*NOTE* I understand that [:7] as highlighted in my original post would not return both spaces in my second scenario, but the [:7] is theoretical for example only.  There are inevitably going to be examples where I have two spaces, but only need one removed if it happens to be the last character.
JamesCrandall
Could you clarify that you want  "SAMPLE" as an output from these possibilities?
"SAMPLE NAME"
"SAM PLE NAME"
" SAM PLE NAME"
" SAM PLE NAME "
DanPatterson_Retired
are you trying to split on spaces? How complex is it going to get? Do you want to close the gap except for the last one? like this one?
a = 'Sam ple space'
a.split(' ')[:-1]
['Sam', 'ple']
# ----  now slice and splice in one go
"".join(a.split(' ')[:-1])
'Sample'
by Anonymous User
Not applicable
jamesfreddyc‌, the variable is the name given to individual features (1000's of them), so there will never be a space at the beginning, but there could be a space anywhere in the name of the feature.  The variable is part of a concatenation script, but I need that concatenation script to adhere to a maximum set of characters.  Since the variable names can range from only a few characters on up to ~100 characters, I need to truncate it.  All other parts of the concatenation are standard, so I need to truncate the feature name to 14 characters or less, which places me right at the limit required.  The problem is that there are instances where the 14th character just so happens to land on a space, and I need to remove that last space in those instances.
Dan_Patterson‌, I don't need to join the strings back together or anything, I just need to remove the last one.
My end concatenation looks something like this:
(AB-CD-EFGHIJKL-12345)-(Variable)-(XYZ)-(01)
The variable portion is what I'm trying to fix.  If the space is left there, then there's an unnecessary space that we want to remove.  Instead of "(SAMPLE_)", we need "(SAMPLE)", however, if the name so happens to be "SAM PLE" then we want to retain that space and end up with "(SAM_PLE)".
MitchHolley1
JamesCrandall
I'm not entirely skilled in string manipulation and there's likely far better solution -- so this is quite limited in scope and would only account for the above scenario if the variable is "SAMPLE " or "SAM PLE NAME".  But perhaps it might give you some ideas.
truncVar = ""
variable = "SAM PLE NAME"
splitVarList = variable.split()
if len(splitVarList) < 3:
    truncVar = splitVarList[0].strip()
elif len(splitVarList) == 3:
    truncVar = "%s%s" % (splitVarList[0].strip(),splitVarList[1].strip())
print truncVar
KevinDunlop
Try
truncVar = variable[:variable.rfind(' ')]‍‍
by Anonymous User
Not applicable
That did the trick.  Thanks, Kevin Dunlop‌!
This is exactly what I was looking for:
