Truncate String - Remove Space
8391
17
09-26-2017 11:41 AM
by Anonymous User
Not applicable
I'm trying to implement a truncation in my script, which is easy enough, but I need to make the overall script smart enough to remove the last character if it happens to be a space.
For instance, if I have the following code:
  1. variable = "SAMPLE NAME"
    truncVar = variable[:7]‍‍‍‍‍‍‍‍
This ends up returning "SAMPLE ", which is right, but there's a space at the end of the string.  I need the script to check for that space, and delete it if it's there, otherwise leave the last character.  I can't just reduce the truncated value since the actual names in the variables will vary widely.
Thanks!
Working Script based on correct answer:
variable = "This is a test variable"
trunc = variable[:10].strip()
result = "'" + trunc + "'"
print result
'This is a' # The strip operation removed the ending space, but it left all others
JamesCrandall
I was under the impression that this also needs to account for "SAMPLE NAME" or "SAM PLE NAME"
by Anonymous User
Not applicable
James Crandall‌, I didn't test this out fully enough.  It worked on the sample I had above, but I ran this same test on different variables and it didn't quite work.  I was a bit too hasty there.
trunc = variable[:8]
string = "'" + trunc + "'"
print string
'SAMPLE N' # last character is not a space
truncRemove = trunc[:trunc.rfind(' ')]
string2 = "'" + truncRemove + "'"
print string2
'SAMPLE' # I don't want the "_N" removed
# Since the last character returned in trunc is not a space, the desired result is what was returned in the first print string operation
Thanks for catching that, jamesfreddyc
JoshuaBixby
MVP Esteemed Contributor
Mitch Holley‌ already provided the answer, i.e., set your truncation width and then simply run strip() to remove any leading or trailing spaces.
>>> trunc = variable[:7].strip()
>>> print string
'SAMPLE'
by Anonymous User
Not applicable
This does seem to check out.  I was under the impression that strip would remove all spaces, or only a specified character. The example at the link that he provided showed the removal of only the zeros from the string, and that didn't seem to be what I needed.
Thanks for clarifying.
mitchh300‌, thank you for that suggestion.  I have marked your answer as correct.
JamesCrandall
You will still need to account for the possible conditions.
This will work for "SAMPLE NAME".
This will fail for "SAM PLE NAME"
variable = "SAM PLE NAME"
by Anonymous User
Not applicable
Whenever I run the above code that you provided, I get "SAM_PLE" as a result, which is correct given that that makes up the 7 characters.  If I extend that out to 8 characters to grab that extra space, the strip function removes the last space and just returns the 7 characters, which is the desired result since I only want to remove the ending space.
Do you get something different, or are we crossing wires on what the desired results are?
JamesCrandall
if variable = "SAM PLE NAME" then the string result will be "SAM PLE", not "SAMPLE".  I was in response to what Joshua posted
>>> print string
by Anonymous User
Not applicable
I see what you are saying now.  We were crossing wires a bit.  I probably didn't explain what was needed very well.  In using "SAM PLE" as my variable, I wasn't trying to indicate that I wanted them joined, I was just trying to simulate a space, and I used the original variable name that I used from the start so that probably came across confusingly.  I'll use a better example below:
print result
'This is a'
The strip operation removed the last space in the string, but it left all other spaces, which is as desired.
