Can you create custom number formatting in Survey123?
2907
09-18-2017 12:59 PM
RebeccaFuda
I have a barcode field in my survey form.  When the barcode is scanned, the resulting number is always in the format XX-XXXX.  On some devices used within my agency, the camera is not sensitive enough to scan the barcode, so the number must be entered by hand.  Is there a way to set the formatting for this field so that the dash is always there, and the user can simply enter the 6 digits?
JamesTedrick
Esri Esteemed Contributor
Hi Rebecca,
2 things to note:
1) You can set a text format as you describe by using an Input Mask - see Esri custom columns—Survey123 for ArcGIS | ArcGIS .  What you've described might fit 00-0000
2) The upcoming version of Survey123 (2.4) will have some improvements in barcode scanning.
JamesTedrick
Hi Rebecca,
2 things to note:
BRYANHERRON
OK, so in my industry we have what we call Engineering Stationing. Say you have a centerline of a highway and the start of the highway at some road intersection is 0+00, 100' down the road there's a manhole, that manhole is at 1+00. 3000 feet down the road there's an intersection, that would be 30+00. This is Engineering Stationing and in Excel the cell formatting is XX+XX so whatever you type in the "+" is always the 3rd digit from the right. Unless you allow for decimals and change the formatting. So how do I put this into Survey123 for these results on the input?
1+23
12+34
123+45
1234+56
12345+67
