scale bar
3808
6
09-15-2017 02:24 AM
AneeqaAbrar1
I want to add a scale bar on my app. Can someone guide me? I am making my apps using arcgis runtime 100.1
nakulmanocha
The scalebar from ArcGIS.AppFramework.Runtime.Controls 1.0  is based on Runtime 10.2.6 and not for 100.1.
Unfortunately, there is no official implementation available for the scalebar at  Runtime100.1. Runtime hasn't provided one yet. It is in the pipeline for future release.
Hence you have to create your own. This requires some work. Also mapScale property is now a property of MapView instead of Map.
This is just an example to get started. It is not a complete implementation.
Create a new qml as ScaleBar.qml
import QtQuick 2.2
import Esri.ArcGISRuntime 100.1
Item {
    property MapView map: null
    signal clicked()
    signal doubleClicked()
    implicitWidth: 100
    implicitHeight: 50
    width: 100
    height: 50
    Component.onCompleted: {
        if (!map && parent && parent.objectType && parent.objectType === "MapView") {
            map = parent;
    QtObject {
        property real segmentWidth: scaleBar.width / 4
        property real segmentHeight: scaleBar.width * 0.05
    Column {
        width: parent.width
        spacing: 0
        Text {
            width: parent.width
            text: "1:" + Math.round(map.mapScale).toLocaleString()
            horizontalAlignment: Text.AlignHCenter
            elide: Text.ElideRight
            font {
                pointSize: 10
                bold: true
        Item {
            width: parent.width
            height: internal.segmentHeight * 2
            Column {
                anchors.fill: parent
                Repeater {
                    model: 2
                    Row {
                        property int rowIndex: index
                        Repeater {
                            model: 4
                            Rectangle {
                                width: internal.segmentWidth
                                color: (index + segmentRow.rowIndex) & 1 ? "white" : "black"
            Rectangle {
                anchors {
                    fill: segmentsColumn
                color: "transparent"
                border {
                    color: "black"
        Row {
            width: parent.width
            Repeater {
                model: 3
                Text {
                    text: "d" + index
                    width: parent.width / 2
                    horizontalAlignment: Text.AlignLeft
                    font {
                        pointSize: 10
                        bold: true
        Text {
            width: parent.width
            text: qsTr("units")
            font {
                pointSize: 10
                bold: true
    MouseArea {
        onClicked: {
            scaleBar.clicked();
        onDoubleClicked: {
            scaleBar.doubleClicked();
In your app add this Scalebar
 ScaleBar{
        anchors.left: mapView.left
        anchors.bottom: mapView.bottom
        anchors.margins: 10 * scaleFactor
        map:mapView
For units you can use
map.spatialReference.unit.displayName. Some more work needs to be done to calculate d0, d1, d2 values to change dynamically.
You can choose to work more on this or wait until the official implementation from Runtime becomes available.
KaushikMysorekar
Hi Aneequa,
It's implemented in the Runtime.Controls lib or namespace.
So  import ArcGIS.AppFramework.Runtime.Controls 1.0 in your qml file first
and implement as below along with desired supported properties and behaviour on the scalebar
For example:
ScaleBar {
          anchors {
          left: parent.left
          leftMargin: 40
          bottom: parent.bottom
          bottomMargin: 55
        map: safetyAlertMap
        visible: true
AneeqaAbrar1
Thanks Kaushik,
Can you please tell me where I can find the documentation for this? I'd like to tweak it a bit.
KaushikMysorekar
I will share the formal doc as soon as I find it, in the mean time though - does F2 on the "ScaleBar" work for you in Qt Creator IDE? That should take you to the source - ScaleBar.qml.
AneeqaAbrar1
No it doesn't. QT creater shows  no information on scale bar. Also this is the scale bar I get - which shows no information.
I also feel that  import ArcGIS.AppFramework.Runtime.Controls 1.0 is not entirely compatible with arcgis runtime 100.1
nakulmanocha
import QtQuick 2.2
Item {
    signal clicked()
    implicitWidth: 100
    implicitHeight: 50
    width: 100
    height: 50
            map = parent;
    QtObject {
    Column {
        width: parent.width
        spacing: 0
        Text {
            width: parent.width
            font {
                pointSize: 10
                bold: true
        Item {
            width: parent.width
            Column {
                Repeater {
                    model: 2
                    Row {
                        Repeater {
                            model: 4
                            Rectangle {
            Rectangle {
                anchors {
                border {
                    color: "black"
        Row {
            width: parent.width
            Repeater {
                model: 3
                Text {
                    text: "d" + index
                    font {
                        pointSize: 10
                        bold: true
        Text {
            width: parent.width
            text: qsTr("units")
            font {
                pointSize: 10
                bold: true
    MouseArea {
        onClicked: {
            scaleBar.clicked();
        onDoubleClicked: {
 ScaleBar{
        map:mapView
AneeqaAbrar1
Thank you
