GraphicsLayer addMany finish rendering
872
09-14-2017 11:06 AM
RodrigoFelga
I have a array of graphics that I'm adding to a GraphicsLayer with the following code:
gLayer.addMany(features);
This works correctly but I need to catch when then graphics finished rendering on the map because many times the array has many graphics and I need to show a loading to the user.
RobertScheitlin__GISP
Rodrigo,
   You just need to watch the layer view updating property for false.
view.whenLayerView(gLayer).then(layerView => {
    watchUtils.whenFalse(layerView, 'updating', () => {
        console.log('The layer is now rendered');
RodrigoFelga
Thanks for your reply. I did that but it triggers before the graphics appears on the screen.
Rodrigo,
   That is strange the updating property is suppose to be the property to watch. I have used it and it worked fine on my end. Maybe you can just add a settimeout inside the result function for a couple hundred milliseconds.
