Import Cad Annotation Problem
4193
9
09-13-2017 02:38 AM
vikaswardiya
On performing Import Cad Annotation in arcgis 10.1 to a drawing file. It Displays no data but just field names. Can anyone help me with this. Please find the sample of drawing file in a attachement.
Thanks in Advance
JayantaPoddar
I am able to see the annotations when I use Import CAD Annotation—Help | ArcGIS for Desktop on ArcMap 10.1.
Think Location
vikaswardiya
Sir what could be the possible reason that I am unable to see it.
JayantaPoddar
Could you attach a screenshot of the tool (Import CAD Annotation) with the required parameters filled/checked? Keep the reference scale as 1000.
Think Location
vikaswardiya
Please find the attachment of the screenshots.. and I have ArcGIS 10.1
advanced licence.
vikaswardiya
Sir, this problem is not with all drawing files. Some drawing files
annotations are visible but some are creating problem like this one.
vikaswardiya
Dear sir,
I found a solution, I saved the same AutoCAD drawing file in a lower
version of AutoCAD and then open in ArcGIS and it opened successfully.
Thanks for your concern.
Regards..
JayantaPoddar
Good to know. Thanks for sharing.
Think Location
AdrianWelsh
MVP Honored Contributor
Ah, that is very good to know. This is likely another case of the user using AutoCAD 2018. What we have seen from other users it that 2018 is not yet supported in ArcGIS. Saving it "down" to an older version seems to solve this problem. This support will be coming with future versions of ArcGIS
https://community.esri.com/groups/cadgis-data-integration?sr=search&searchId=c8d3c818-dd03-4966-8edd...
AdrianWelsh
Vikas,
What level of license do you have for ArcGIS? There is limited functionality for Basic level licenses
tagging https://community.esri.com/groups/cadgis-data-integration?sr=search&searchId=26b806df-72a7-43c2-9704...
