Is it possible to move a constraint map based on th xz coordinates of the current view?
1615
09-11-2017 01:44 PM
NicolaiSteinø
I would like to be able to automatically shift a map with a radial gradient (say black to white) for controlling the level of detail. If the center of the radial gradient is always right below my viewpoint, I could use the grey levels to change the level of detail as a function of the distance from the viewpoint. Could this be done with Python?
ThomasFuchs
Hello Nicolai Steinø
Yes, this is possible with a function layer (reference point is the center).
Here is a simple CGA rule that colors buildings by LOD:
attr LOD = 0
@StartRule
Lot --> extrude(rand(10,30)) ColorByLOD
ColorByLOD -->
     case LOD > 3: color(1,0,0)
     case LOD > 2: color(1,1,0)
     case LOD > 1: color(0,1,0)
     else: color(0,0,1)
Make sure the rule attribute LOD is connected to the layer attribute:
When you move the camera, call the following python script:
from scripting import *
# get a CityEngine instance
ce = CE()
if __name__ == '__main__':
    l = ce.getObjectsFrom(ce.scene, ce.isLayer, ce.withName("'LOD"))[0]
    CameraPoI = ce.get3DViews()[0].getCameraPoI()
    ce.setAttributeLayerExtents(l, [CameraPoI[0],CameraPoI[2],3000,3000])
    ce.setLayerAttributes(l, "attr LOD = sin(u * 180) * sin(v * 180) * 4")
    sceneShapes = ce.getObjectsFrom(ce.scene, ce.isShape)
    ce.generateModels(sceneShapes, False)
Then your city should look like this:
NicolaiSteinø
This is genuinely cool! Thanks a lot.
AbeleGiandoso
Amazing!
"Make sure the rule attribute LOD is connected to the layer attribute"
How do you do that?
CherylLau
In the Inspector, click on the drop down arrow next to the rule attribute (see Thomas's screenshot) -> Connect Attribute -> Layer attribute -> select LOD.
