How to use ReportLab in ArcGIS Pro?
4983
09-11-2017 09:23 AM
MelanieFournier1
I just installed the personal use license of ArcGIS Pro. I found on this forum that for reporting, a way to produce a pdf was to use reportlab.
I added Reportlab to my ArcGIS Pro, except that now I am trying to create my PDF and I am kind of lost.
I looked on forums, and what I globally found was how to use report lab from your computer but not linked to ArcGIS Pro.
Could you please tell me how I am suppose to get access to reportLab within ArcGIs Pro and generate my PDF?
Thank you.
M.
DanPatterson_Retired
reportlab is used within your scripting environment.
are you looking for an interface to it?
If you check to see if it is installed in your Pro package environment, you are ready to use it
import reportlab
MelanieFournier1
Not sure if my reply arrived to you. Thanks! It work perfectly. I can now create reports.
Nope... just saw this marked as 'assumed answered' .... glad it worked out
MikeVolz
Dan - Are you supposed to be able to access ReportLab from the default python environment of Pro or do you need to clone python and add ReportLab thru Package Manager?
