Create an array of data in AGOL for use in arcade expression
2272
09-05-2017 09:48 AM
AmySorensen
I would like to use Arcade in order to create a map that keys off when conditions are met. The first step to get there would be to perform a count of the number of items that are entered for a specific area.
Say we have a field of shapes that are either in group A or B. I would like to add to the pop up what the total count of B is using Arcade. I would like to use Arcade since this value is changing over time.
I believe if I could create an array of all the values then I could use this with Arcade to complete the code. I'm working purely in AGOL.
Any suggestions would be appreciated!
Tags (3)
NaomiBegg2
Xander Bakker‌ is this something you can answer?
I'm trying to use arcade in a field calculator to create a status field.  I'm using when and have quite a few different conditions for it to run through.
One of the few conditions involve checking if a number matches one within a list.  I could do number IN (....,....,....) however I thought it would be cleaner to declare this list at the top along with other var.
How do I do this?
XanderBakker
Esri Esteemed Contributor
Hi Naomi Begg ,
Since this question is a bit off-topic from the original question posted by the OP, you might want to branch this question to a new question. However, let's see if I can answer part of your question.
You mention you want to validate the number of matched in a list. Where is this list coming from? Is it hardcoded? What is the code that you have already? Where is the data coming from?
