clicking base map throws error
1100
08-31-2017 09:51 AM
EvonFranklin
After clicking anywhere on the base map I get an error in console saying
Uncaught TypeError: Cannot read property 'position' of undefined
at Object.b.hitTest (MapView.js:699)
at Object.c.hitTest (MapView.js:694)
at MapView.js:735
at Array.map (<anonymous>)
at Object.c.hitTest (MapView.js:735)
at Object._clickHandler (init.js:2063)
at init.js:49
at a._callback (MapView.js:625)
at c._handleEvent (MapView.js:560)
at Object.eventCallback (MapView.js:556)
I have a MapView.on('click',callback()) attached to the mapview however even after I comment out this entire code block I still get the error when clicking anywhere on the base map.
Tags (1)
KenBuja
MVP Esteemed Contributor
It would help if you posted your code.
ThomasSolow
Also, in the sample you posted, you're invoking the callback when you really want to pass it in as an argument.  Try removing the ().
EvonFranklin
MapView.on("click", function(evt){
                                             if(view.zoom < 12){
                                                   return;
Funny thing, even if I comment out this code I still get that error in console.
KenBuja
So what else is in your code? What are the require modules and function arguments, for example? You could have a mismatch between them.
