ArcMap Serch button is not working
839
08-31-2017 09:35 AM
M__S__P__M_Siriwardane
When clicking on the search button of the ArcMap nothing happens. Even the search window is not coming. But ArcCcatalog it is working. ArcMap version is 10.3. OS widows 8.
JayantaPoddar
Try Resetting your ArcGIS application profile‌. Hopefully, this should fix the issue.
Think Location
I repaired ArcGIS installation and also reset the Application profile but still the issue is not solved.
shan_sarkar
Supun,
  1. Login to your machine with a different user profile and check if the issue replicates.
  2. Login to a different machine (which has ArcGIS Desktop installed) with your profile and check if the issue replicates.
~Shan
~Shan
