Increment Survey Numbers
2544
08-29-2017 09:23 AM
MichaelLathrop
Hey Team,
Is there any way to auto-increment survey numbers (e.g. 1,2,3,4)? I have a Survey 123 Form that I'd like to make improvements on for our staff to collect data in the field. To address the duplicated numbers I've given them an assigned series, (i.e 10-###, 20-###) and have created separate forms for each of them to avoid duplicating survey numbers. It would be so much nicer to have this done "auto-magically" when conducting their surveys.
Respectfully,
Michael
JamesTedrick
Esri Esteemed Contributor
Hi Michael,
Survey123 does not support auto-incrementing numbers currently; as you note, some careful construction needs to be considered and made in order to ensure duplicates are not submitted.
AngusKing
Hi Micheal, any chance that we could get auto-increment numbers added to survey123?
by Anonymous User
Not applicable
Hi Michael,
Ismael wrote a good blog post on this topic a few months ago, check it out here: https://community.esri.com/groups/survey123/blog/2017/11/25/creating-ticket-numbers-in-survey123-for...
Phil.
DougBrowning
MVP Esteemed Contributor
I got this simple one to work now
I got this to work for repeats
In a repeat have a field with a calculate (it can be editable)
Use this formula subbing in any field in the repeat (except itself)
        once(count(${RecKey}))
ref https://community.esri.com/message/787003-re-survey123-functionality-calculate-position-in-repeat-gr...
