Failed to update custom HTML banner using set_banner() method
1286
08-25-2017 02:47 AM
IonutAlixandroae4
I tried to update the banner to my Developer ArcGIS Online account and although the return was True, the home page is still default.
I am using custom HTML & CSS that I read from a .txt file and that variable I`m passing as a parameter to the method.
The .txt file has custom html elements and css into it, which, if I take it with copy-paste, it`s working just fine.
Has anyone encountered this problem?
Ionut
by Anonymous User
Not applicable
Ionut there was a bug with setting banners using custom HTML which we fixed recently. Please check the next version (v1.2.4 or later) for this fix.
IonutAlixandroae4
Hi Atma,
Thanks a lot for the info. Current version is 1.2.2; do you have any idea when 1.2.4 will be released?
Ionut
by Anonymous User
Not applicable
We are planning a major release by the end of the year. But it is quite possible that we may do a bug-fix release earlier than that. Sorry, I cannot give you specifics at this point.
