Drawing polygon and adding buffer to it
2467
7
08-25-2017 02:19 AM
PaulinaR
Hi!
I would like to draw polygon on my map and afterwards add 1,5 m buffer to it. I managed to draw a polygon however I have no idea how to create a buffer. The idea is that a user of ArcGIS will draw a polygon and receive directly the buffer. Is that possible?
def onLine(self, line_geometry):
        array = arcpy.Array()
        part = line_geometry.getPart(0)
        for pt in part:
            print pt.X, pt.Y
            array.add(pt)
        array.add(line_geometry.firstPoint)
        polygon = arcpy.Polygon(array)
        # Local Variables
        Input = polygon
        NewPolygons = "\\\\abc\\home\\xxx\\Documents\\moje dokumenty\\xyz\\arcgis\\new polygons"
        # Process: Append Polygon to existing file or Create new file if one is not created.
        if arcpy.Exists("NewPolygons"):
            arcpy.Append_management(Input, NewPolygons, "Test", "", "")
        else:
            arcpy.CopyFeatures_management(Input,NewPolygons, "", "0","0","0")
        print " Excavation Polygon located"
PaulinaR
I have managed to create a buffer (see below). Does somebody know how to add transparency to the polygon and to the buffer? EDIT:/ I added to the polygon (
        ExcavationPolygon.transparency= 60 ) but unfortunately for buffer it shows error.
        for pt in part:
            print pt.X, pt.Y
            array.add(pt)
        # Local Variables
        Input = polygon
        else:
        # Buffer areas of impact around major roads
        ExcavationPolygon = arcpy.CopyFeatures_management(Input,NewPolygons, "", "0","0","0")
        PolygonBuffer = "\\\\abc\\home\\xxx\\Documents\\moje dokumenty\\xyz\\arcgis\\PolygonBuffer"
        distanceField = "1.5"
        sideType = "OUTSIDE_ONLY"
        endType = "ROUND"
        arcpy.Buffer_analysis(ExcavationPolygon, PolygonBuffer, distanceField, sideType, endType)
        print "Buffer of 1.5 m completed" ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
Like most geoprocessing tools, Copy Features returns an ArcPy Result object, and there is no transparency property for a Result object.  Even if there was a transparency property, it would be the transparency of the result object itself and not the feature class the tool created.  In short, trying to set the transparency of ExcacationPolygon won't work for multiple reasons.
As you have already found out, or at least read about, setting the transparency of a layer is fairly simple since the ArcPy Layer class has a transparency property.  The trick is getting a reference to the layer object so you can set the transparency property.  Before I give specific suggestions, how exactly are you executing your code?  I assume it isn't in the interactive Python window since you have other users executing the code.  A script tool?  If so, what are the settings for in-process, etc...?  Are you just running default settings?
curtvprice
If running for ArcMap, Pro, or even publishing to a geoprocessing service, this is easily done without futzing with geometry objects by setting up the input to be a Feature set,
Working with feature sets and record sets—Help | ArcGIS Desktop
and setting the symbology property of the output to a layer file.
Setting script tool parameters—Help | ArcGIS for Desktop
PaulinaR
Thank you for your help Joshua and Curtis! I am using Notepad++. I created an Add-in for ArcGIS using add-in wizard.
PATH_TO_XYZ_FOLDER = "\\\\abc\\home\\xxx\\Documents\\moje dokumenty\\xyz\\arcgis"
MY_WORKSPACE="\\\\abc\\home\\xxx\\Documents\\ArcGIS\\Default.gdb"
PaulinaR
I have one more question. In the next step  I want to create a grid on buffer. Nevertheless, I need to do it in different class and I would like to set buffer as global variable. Do I make it correctly? because It shows me error (global name 'ExcavationZone' is not defined)when I push the grid button . I added global variable at the end of above mentioned code. Thanks a lot for any help!
global ExcavationZone #Setting excavation zone as global variable in order to use it later
        ExcavationZone= arcpy.Buffer_analysis(ExcavationPolygon, PolygonBuffer, distanceField, sideType, endType)
        print "Excavation Zone established"
curtvprice
All variables set at the top level in a .py file are global. It's generally not good practice to use global if you don't have to.
"ExcavationZone =" is setting a result object , which when str()'d or provided as a parameter as a tool (again str()'d) will resolve to the pathname (full path for the python variable PolygonBuffer, this string should be set before running the tool).
PaulinaR
thank you for help!
