'Text' vs 'String' keyword for field attribute creation and description
11101
08-23-2017 06:36 AM
GeorgeNewbury
Any idea why the input requirements for adding a string/text field is different than the 'type' attribute for a string/text field?
For example:
myfc  =  r'C:\Foo\bar.gdb\somefc'
arcpy.AddField_management(myfc, 'MyStringField', 'TEXT',5)
myfc_pyobject = arcpy.ListFields(myfc,'MyStringField')[0]
myfc_pyobject.type would print out 'String'
Seems like they should be the same.
George
JoshuaBixby
MVP Esteemed Contributor
Consistency would be great, but this is covered/addressed in the Field—Help | ArcGIS Desktop :
The field type.
  • Blob —Blob
  • Date —Date
  • Double —Double
  • Geometry —Geometry
  • GlobalID —Global ID
  • Guid —Guid
  • Integer —Integer (Long Integer)
  • OID —Object ID
  • Raster —Raster
  • Single —Single (Float)
  • SmallInteger —Small Integer (Short Integer)
  • String —String (Text)
Similar/same data types aren't always called the same thing in different systems, and ArcGIS has to balance data type names between ArcObjects, Python, DBMSs, etc....  I think "string" is more common in programming languanges but "text" is more user friendly.
JoshuaBixby
The field type.
  • Blob —Blob
  • Date —Date
  • Double —Double
  • Guid —Guid
  • OID —Object ID
  • Raster —Raster
GeorgeNewbury
Thanks, I've probably seen that part of the help 100s of times but never actually digested the 'String to TEXT' part in the note.
George
