How to query CSV URL from AGO
641
08-18-2017 08:31 AM
JasonCarter1
I am working on building a web application and I'd like to know if it is possible to query a hosted CSV file from a URL in AGO WebApp?
For instance, I can feed in the USGS earthquake information (https://earthquake.usgs.gov/earthquakes/feed/v1.0/csv.php ) and add the data points to my map. I can then perform analysis on this layer in the Web Map, but not in a Web App. I understand that to query layers they need to be feature layers, but why can I perform queries in the Web Map but not in a Web Application? The only solution I've seen to convert this CSV into a feature layer while maintaining the live stream is by using JavaScript. Is there a way to do this in the Web App builder?
RobertScheitlin__GISP
Jason,
   This would only be possible if you are using WAB Dev and make some modifications to the code base to allow for this.
