How to add a map extent indicator inset?
920
08-15-2017 10:18 AM
PeterLen
I am using the Esri Javascript v3.9 (yes, I know it is older) and am trying to find some info on the best way to add an extent indicator (or whatever it is called) to my web map.  I essentially want a small map displayed in an inset in the bottom left or right corner on my main map where the inset is the same map location but zoomed out a couple of levels with the main map's extent outlined in the inset.  I found sort of an example that uses the Google Maps API, but am trying find a good example using the Esri javascript API so that I will know how to best build it.
Thanks - Peter
KellyHutchins
Esri Notable Contributor
Take a look at the OverviewMap widget it should do what you need and it has been available since version 2.0 of the ArcGIS API for JavaScript.
OverviewMap | API Reference | ArcGIS API for JavaScript 3.21
KellyHutchins
PeterLen
Kelly - Yes, this appears to be exactly what I am looking for.  I just couldn't find the right search words to use.  I really appreciate your quick response and finding exactly what I was looking for.  Much appreciated - Peter
