Using Calculations for Multiple choice questions
1160
08-14-2017 07:28 AM
Lake_Worth_BeachAdmin
I am attempting to replicate this paper form in Survey 123.
There are multiple choices (can be more than one) for each answer there is an associated $$$ value.
I want all selected choices $$$$ value totaled in the total charge- field to be added automatically.
I am not even sure how to assign a integer value to these choices with a text label in the multiple choice question type.
Should I even be using this question type or is there a better solution? see image below of what I am trying to replicate.
JamesTedrick
Esri Esteemed Contributor
Hi Joe,
There are couple of ways to consider replicating the functionality form, though we can't replicate the exact layout.  The first would be to have a list of questions that have the charge; set the default to 0 and sum them up (essentially, rely on the fact that you charge them something means that it's "selected").  The second method would be to have a repeat section where you select the charge reason and charge and then sum that up; this would prevent you from having empty charge codes
I was doing this with multiple choice question type... but the functionality wasn't working. I created a case# : 01974565 and they are looking into it. may be a bug. it was a simple sum calculation.
