promise object in node.js
1240
08-05-2017 12:30 AM
ZakiEldsoque1
how make promise object using in dojo to execute task work sequentially  in node.js ?
ThomasSolow
Promises in node are the same as promises in the browser.  If you're pulling in dojo, you can use dojo/deferred.
The JS standard library also has a promise implementation, just Promise, that is mostly compatible with the dojo version.
This looks helpful for information about using dojo in node: Dojo and Node.js - Dojo Toolkit Tutorial
