Is ArcGIS collector honor definition query in map layer?
1818
08-01-2017 07:04 PM
Abdul_LahelShafey2
Is ArcGIS collector honor definition query in map layer? I have created several layers based on the attribute definition query from same data source then publish feature service in ArcGIS online. My definition query wit working fine with Collector in online mode but it’s not working in collector offline mode. The definition query is not honoured in Offline mode. Is there anyway can create map layer using filter and give support in both online and offline mode?
SamuelGould
I have run into this issue as well.  I had to get creative with symbology and extra processing to get the desired display that would have been simple with a definition query.  Is the expectation that Collector will honor a definition query when offline or is this a known limitation?
Manuel_RRegalado
Hello, did you end up solving this issue? I am running into the same problem. In the ArcGIS Server Manager I see the following error but it was only after I added the definition query.
ORA-01861: literal does not match format string error
