Why don't my attributes display when using editor widget from API 3.21?
1056
07-27-2017 09:39 AM
ChrisSeabrooke
I'm new to JavaScript and the API. I'm trying to modify the default editing widget:
Default editing widget | ArcGIS API for JavaScript 3.21
When I change the URL to my feature service, only one field  displays in the form. I tried different features from my service and still only one field displays. The field that displays is the  ‘Type ID Field’  in the layer. A snippet from my code:
var operationsPointLayer = new FeatureLayer("http://50.18.50.62:6080/arcgis/rest/services/FieldSeekerMobile3/FeatureServer/15", {
mode: FeatureLayer.MODE_ONDEMAND,
outfields: ["*"]
map.addLayers([operationsPointLayer]);
map.infoWindow.resize(400, 300);
function initEditing(event) {
var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
return { "featureLayer": layer.layer };
var settings = {
map: map,
layerInfos: featureLayerInfos
var params = {
settings: settings
var editorWidget = new Editor(params, 'editorDiv');
editorWidget.startup();
//snapping defaults to Cmd key in Mac & Ctrl key in PC
// specify 'snapKay' option only if you want a different key combination
// for snapping
map.enableSnapping();
Any suggestions will be appreciated.
ChrisSeabrooke1
Determined what I was doing wrong - I had
outfields: ["*"]
Needs to be
outFields -- capitalization error.
SarojThapa1
Chris,
Change http to https in your
var operationsPointLayer = new FeatureLayer("https://")
ChrisSeabrooke
Saroj,
Now the layer doesn’t display in the map. In the console I have this message:
Failed to load resource: net::ERR_SSL_PROTOCOL_ERROR
15 Failed to load resource: net::ERR_SSL_PROTOCOL_ERROR
Error: Unable to draw graphic (geometry:null, symbol:null): Error loading https://50.18.50.62:6080/arcgis/rest/services/FieldSeekerMobile3/FeatureServer/15?f=json&callback=do...
ChrisSeabrooke1
outfields: ["*"]
Needs to be
