Why does ArcGIS 10.5 crash when my python script calculates summary statistics
2422
5
07-18-2017 04:33 PM
RobertRyan3
The python script calculates drainage areas and land use.  It seems to run fine until the Summary Statistics part when ArcGIS crashes.  I'm running ArcGIS 10.5.  Any ideas what might be causing this?  I've attached the python script
DanPatterson_Retired
since the last parameter is optional, did you try to drop it?
    arcpy.Statistics_analysis (tabIntersectSave, sumStatsSave, [["AREA","SUM"]], siteNameColumn)
to arcpy.Statistics_analysis (tabIntersectSave, sumStatsSave, [["AREA","SUM"]])
assuming all the other parameters are correct
and also as a check, your field is called 'AREA' and not SHAPE_Area or something... (this looks like it is the result of a modelbuilder output can you confirm)
RobertRyan3
Dan, thanks for your suggestion. Once I deleted the last parameter as you
suggested, the code ran without causing ArcGIS to crash. However, I then
got an error that the parameter "Sum_Area" in the next line of code did
not exist. However, when I open the sumStats file it is there. Any
thoughts about that?
Robert J. Ryan, Ph.D., P.E.
Associate Professor
Senior Design Coordinator
Civil and Environmental Engineering Department
Temple University
1947 N 12th St
Philadelphia PA 19122
Office: EA515
Phone: 215-204-3054
Fax: 215-204-4696
ok modelbuilder outputs should be checked by at least one manual run per step and then examining the contents of the Results window.
When you edit the line above to make it stop crashing... you then have to examine the next line
arcpy.JoinField_management (tabIntersectSave, siteNameColumn, sumStatsSave, siteNameColumn, "SUM_AREA")
and unless you deleted the field, then it would obviously exist.  Always start with a clean version of the input files when testing a model or a script.
I suggest you isolate that particular step in the workflow and check to see whether the fields do or do not exist in the prior step.
RobertRyan3
Thanks. I will try this and let you know how it works out.
Associate Professor
Temple University
1947 N 12th St
Office: EA515
Phone: 215-204-3054
Fax: 215-204-4696
Robert... resolved?
