Building android app with Cloudmake fails
2635
07-07-2017 09:46 PM
by Anonymous User
Not applicable
Hi all,
I am trying to build an Android app using CloudMake, but it fails due to the certificate file I'm using.
I followed the instructions here to create the keystore file:
Sign your app—AppStudio for ArcGIS | ArcGIS
but get the following error message:
No key.store and key.alias properties found in build.properties.
jarsigner command failed.
jarsigner error: java.lang.RuntimeException: keystore load: Keystore was tampered with, or password was incorrect
Any ideas what could be causing this?
StephenQuan1
Hi Paul,
There were some issues with the Cloud Make service causing some downtime Saturday afternoon and Sunday. I've identified and rectified all the issues. Can you please try again?
Stephen
by Anonymous User
Not applicable
So, after a bit of thinking, it seems that it didn't like a particular character in the password. Changed the password and the build seems to work.
I did some searching but couldn't find any info on the web about password character requirements - if anyone knows of any then perhaps add a comment here for future reference....
hishamshrideh1
Hello Paul ,
Also I'm try to build my app using cloud build , and I get message build failed -internal server error 401 .
Do you have same problem ?
Please any one advise us
Thank you
StephenQuan1
Hi Paul,
Stephen
by Anonymous User
Not applicable
Hi Stephen
I'm not having issues anymore - I'm not sure if my problem was related to the server issues or not. As mentioned above, I suspect my issue was due to password requirements.
Cheers,
-Paul
