sIs it possible to generate multiple maps based on different fields of a single shapefile?
602
07-06-2017 09:45 AM
FarhanMustafa
I am generating maps of a province which contain details about population growth of 36 cities temporally (2000, 2004, 2008, 2012, 2016). These values are stored in attribute table of the shapefile as fields like pop2000, pop2004 etc. I have to generate map for each i,e 2000, 2004, 2008, 2012, 2016. In each of the map, like if I am generating 2008 map, I want the values of field 2008 to be displayed in table. I already have done work with tables and graphs successfully. I just want to know:
1. From a single MXD, I want to generate all the maps in a single PDF as Final Output.
2. The map and layout for each of the maps will be same, just values of population growth will be changed, the required values should be got from the fields stored in attribute table of the shapefile.
Regards
