Error Code 502 and 503
10988
16
06-28-2017 02:01 PM
DanielDePinte
I am working with Survey123, trying to work out a totally different bug (error code 1003), and to do this I am attempting trial and error methods, which involves changing one thing and republishing the survey. I notice that as the middle of the day comes around I start receiving error codes 502 and 503. Sometimes one then sometimes the other. I am assuming it is trouble with servers or something upstream having to do with too much traffic on the server in the middle of the day, since I can run things fine early in the morning and late in the evening. I would like to be able to work on issues during normal working hours (crazy right?) is there something you all at ESRI can do to fix this? Thanks and cheers!
RebeccaStrauch__GISP
Have you thought about using if offline, and least for testing purposes?
Prepare basemaps for offline use—Survey123 for ArcGIS | ArcGIS
https://community.esri.com/groups/survey123/blog/2017/01/31/taking-your-maps-offline-with-tile-packa...
Might not resolve all your issues, but at least it might lessen the stress while tweaking.
tagging https://community.esri.com/groups/survey123?sr=search&searchId=da00784d-9d78-4489-9d5c-f55a5758fd3d&...‌  for more exposure
DanielDePinte
Thanks that makes sense. I will take out the geopoint question to speed up the process.
DanielDePinte
So, know the tablet just keeps searching for feature service............one step at a time. Good thing I have multiple projects going on to jump around on.
ZachMueting
I'm getting this same error.  I hope it can be resolved.  My team is about to dump Survey123 with all the little problems we keep having with it.
In case you haven't been following Arconline Issues?  today
ZachMueting
It's up again!  Thanks.  Do you know why images might not be coming through?  I had to delete all the image questions in our Connect survey because they wouldn't send.
I don't, but very much could be related.  Not sure if KGerrow-esristaff‌ has anything to add, so tagging her.
KellyGerrow
Esri Alum
HI rjmdesign,
I can't be sure what is causing the issue. I'd suggest getting in contact with technical support to see if they can verify the issue that you are running into and how to move forward. Let me know if you need help getting in touch with support.
-Kelly
ZachMueting
It seems to be down again.  My team is going to give it till tomorrow.  Is this normal for the afternoon hours?
