related to upgrade? error when I try to export data from a feature layer.
1135
06-28-2017 12:16 PM
JulieFrench
I'm getting a pop up error when I try to export data (to CSV or to Excel) from a feature layer.  The pop up says "Error: Export service error Exception: Not Found". Is this related to the upgrade intermittent issues, or is this something else? (I've been trying to export since Thurs 6/27 around 11pm eastern and have tried several times today and still getting the same error).
KellyGerrow
Esri Alum
Hi Julie,
Is the layer that you are exporting from a result from an analysis service? If so, there is an issue that was found that will be fixed tomorrow night. If the data was created in another way, I recommend contacting technical support to get this issue investigated as soon as possible.
-Kelly
JulieFrench
Thanks Kelly.  Yes, the feature layer was a result of 'overlay layers'. I'll give it a try again once the issue has been fixed. Thanks.
