Passing attribute value as a variable with ArcGIS JavaScript
1572
06-21-2017 03:14 PM
PattyJula
I want to get the value of an attribute when a user clicks on a feature. Building off this example: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=tasks-identify. Does anyone know how I can, for example, get the value for DomOrd in the layer Soil Survey Geographic? The following code snippet is from the above example.
 if (layerName === 'Soil Survey Geographic') {
//the following two lines are similar to what I want, but they don't work
 var attributeVal = result.layerName.DomOrd;
console.log(attributeVal);
 feature.popupTemplate = { // autocasts as new PopupTemplate()
 title: "{Map Unit Name}",
 content: "<b>Dominant order:</b> {Dominant Order} ({Dom. Cond. Order %}%)" +
I need to pass the attribute value in an SQL query with ColdFusion - so that's why I need the value.
#arcgis javascript 4.3
Tags (1)
KenBuja
MVP Esteemed Contributor
Here's how to get the value from the field DomOrd. You have to use the field alias to get it
var attributeVal = feature.attributes["Dominant Order"];‍
