Unexpected error had occurred when creating the package.
1708
06-15-2017 08:47 AM
AlexCarrier
I am trying to create a tile package of part of a county in Florida. I have created a couple of different tpk's of other areas using the same method, however this time I am getting this error message:
All of my data is in Web Mercator. To create this tpk I am going to File > Share As > Tile Package. My zoom level is set to 20, tile format PNG. I am trying to create this tpk for Survery123. Any suggestions on what settings to check? Thanks in advance!
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
Unfortunately, the error you are getting is very generic.  One thing I would check is that the destination disk for the TPK has enough free space to store the TPK.  I might also suggest using the geoprocessing tool rather than the Share As- it might give you a better error message if it can't generate the TPK.
WilliamWang
Good day James,
I ran into similar problem as Alex and I took your advice to run the creation via GP tool.
This is the message I got.
I am running on 10.41 standard AM license.
In my mxd, I have a MrSID layer. I also saw this post which was also initiated by Alex. I am wondering if this is what you were referring to. My alternative is to create a TPK from a raster dataset which worked but the file size was 17Gig vs 5 Gig MrSID layer. Public safety is my primary consumer for the TPK. Appreciate any pointers. Thanks.
JamesTedrick
Hi William,
A couple of things will present problems:
- A TPK re-rasterizes the imagery into PNG/JPG; a MrSID doesn't provide any storage benefits and isn't supported
- There are a couple of issues with large TPKs
   - Because we support 32-bit operating systems, Survey123 can't use a TPK larger than ~2GB
   - Many Android phones may not support SD cards that allow for files larger than 4GB
