How to implement restriction on routing?
1904
06-15-2017 12:55 AM
LeoDeng
All,
   I'm using esri javascript api 3.20.
   I want to implement an ONE-WAY restriction for route analysis.
  The network server (NAServer) has an attribute "Driving a Passenger Car". (TomTom North America data)
  In arcmap, the results are as expected.
But when using esri js api, the results was
How to apply the one-way restriction?
var layer = new GraphicsLayer({id: 'route'});
map.addLayer(layer);
var features = [];
var p1 = new Graphic(new Point(-73.936131, 42.818060), stopSymbol);
var p2 = new Graphic(new Point(-73.936946, 42.819637), stopSymbol);
features.push(p1);
features.push(p2);
layer.add(p1);
layer.add(p2);
var featureSet = new FeatureSet();
featureSet.features = features;
parameters.stops = featureSet;
parameters.outSpatialReference = {wkid: 3857};
parameters.returnStops = true;
parameters.returnDirections = true;
parameters.directionsTimeAttributes = "Minutes";
parameters.outputLines = NATypes.OutputLine.TRUE_SHAPE;
parameters.doNotLocateOnRestrictedElements = false;
parameters.attributeParameterValues = [{
     "attributeName": "Driving a Passenger Car",
     "parameterName": "Restriction Usage",
     "value": "Prohibited"
parameters.restrictionAttributes = ['Driving a Passenger Car'];
task.solve(parameters).then(function(results){
     var routeResults = results.routeResults[0],
          route = routeResults.route;
     route.setSymbol(routeSymbol);
     layer.add(route);  // the route without restriction
}.bind(this), function(error){
     console.log(error);
}.bind(this));‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Tags (1)
LeoDeng
I'm trying to use travel mode option, but the result is same as before.
task.getServiceDescription().then(function(results){
    var travelMode = results.supportedTravelModes.filter(function(item) { return item.name == "Driving Time" })[0];
    parameters.travelMode = travelMode;
        layer.add(route);
        console.log(error);
    }.bind(this));
The travel mode description
{"name":"Driving Time",
"id":"1",
"type":"AUTOMOBILE",
"description":"Models the movement of cars and other similar small automobiles, such as pickup trucks, and finds solutions that optimize travel time. Travel obeys one-way roads, avoids illegal turns, and follows other rules that are specific to cars. Dynamic travel speeds based on traffic are used where it is available when you specify a start time.",
"timeAttributeName":"TravelTime",
"distanceAttributeName":"Kilometers",
"impedanceAttributeName":"TravelTime",
"restrictionAttributeNames":
["Avoid Unpaved Roads",
"Avoid Private Roads",
"Through Traffic Prohibited",
"Roads Under Construction Prohibited",
"Avoid Gates",
"Avoid Express Lanes",
"Avoid Carpool Roads",
"Avoid Pedestrian Zones",
"Avoid Roads for Authorities",
"Avoid Service Roads",
"Avoid Walkways"],
"attributeParameterValues":
{"attributeName":"Driving a Passenger Car",
"parameterName":"Restriction Usage",
"value":"Prohibited"},
{"attributeName":"Driving a Public Bus",
{"attributeName":"Driving a Residential Vehicle",
{"attributeName":"Driving a Taxi",
{"attributeName":"Driving a Commercial Vehicle",
{"attributeName":"Driving a Truck",
{"attributeName":"Avoid Ferries",
"value":"Avoid_Medium"},
{"attributeName":"Avoid Toll Roads",
{"attributeName":"Avoid Service Roads",
{"attributeName":"Avoid Pedestrian Zones",
{"attributeName":"Avoid Walkways",
{"attributeName":"Avoid Roads for Authorities",
{"attributeName":"Avoid Roads in Poor Condition",
{"attributeName":"Avoid Private Roads",
{"attributeName":"Roads Under Construction Prohibited",
{"attributeName":"Avoid Back Roads",
{"attributeName":"Avoid Limited Access Roads",
{"attributeName":"Avoid Unpaved Roads",
"value":"Avoid_High"},
{"attributeName":"Through Traffic Prohibited",
{"attributeName":"Avoid Express Lanes",
{"attributeName":"Avoid Carpool Roads",
{"attributeName":"Avoid Gates",
{"attributeName":"Avoid Truck Restricted Roads",
{"attributeName":"Any Hazmat Prohibited",
{"attributeName":"Height Restriction",
"parameterName":"Vehicle Height (meters)",
"value":0},
{"attributeName":"Length Restriction",
"parameterName":"Vehicle Length (meters)",
"value":0},
{"attributeName":"Trailer Length Restriction",
"parameterName":"Trailer Length (meters)",
"value":0},
{"attributeName":"Use Preferred Hazmat Routes",
"value":"Prefer_Medium"},
{"attributeName":"Use Preferred Truck Routes",
{"attributeName":"Weight Restriction",
"parameterName":"Vehicle Weight (kilograms)",
"value":0},
{"attributeName":"Weight per Axle Restriction",
"parameterName":"Vehicled Weight per Axle (kilograms)",
"value":0},
{"attributeName":"Width Restriction",
"parameterName":"Vehicle Width (meters)",
"value":0},
{"attributeName":"Riding a Bicycle",
{"attributeName":"WalkTime",
"parameterName":"Walking Speed (km/h)",
"value":5},
{"attributeName":"Walking",
"value":"Prohibited"}],
"useHierarchy":true,"uturnAtJunctions":"esriNFSBAtDeadEndsAndIntersections",
"simplificationTolerance":null,"simplificationToleranceUnits":"esriUnknownUnits"}"
