Selecting lines with an endpoint within a distance of a point feature class
2575
06-12-2017 02:55 PM
TessOldemeyer
Any ideas on ways to select line features that have an endpoint/node within a distance of a point feature class? I have been using arcpy.SpatialJoin_analysis and arcpy.SelectLayerByLocation_management to achieve selecting all lines that fall within a specified distance of a point feature class; though, I want to make sure I do not capture lines that may fall within the search radius of a point but do not have and endpoint within the same search radius (e.g. just passing nearby within the search radius). I don't see this type of selection as a built in function for either arcpy.SpatialJoin_analysis or arcpy.SelectLayerByLocation_management, but I may have missed something. This would be a very useful functionality if it exists.
LukeWebb
Use tool "Feature Vertices to Points" to convert the lines to start and end points, then join to them.
DanPatterson_Retired
You could also compare results with Near or Generate Near Table which would identify segments who are closest/within a distance of the points but whose endpoints may not be.
LukeWebb
TessOldemeyer
I think this'll do the trick. Thanks!
