Example to copy portal content
3111
7
06-10-2017 12:40 AM
PhilipHughes
trying to used the example listed in the site,  there a few typo errors that obvious however I getting a traceback error
  File "copy_to_mgq.py", line 398, in <module>
    target.content.create_folder(folder, user)
  File "C:\Continuum\Anaconda3\lib\site-packages\arcgis\gis.py", line 1665, in create_folder
    if self._portal.get_folder_id(owner_name, folder) is None:
  File "C:\Continuum\Anaconda3\lib\site-packages\arcgis\_impl\portalpy.py", line 2192, in get_folder_id
    if fldr['title'].upper() == folder_name.upper():  # Force both strings to upper case for comparison
AttributeError: 'dict' object has no attribute 'upper'
This is from the line "target.content.create_folder(folder, user)"  am guessing this a problem in the esri code
RohitSingh2
Hi Philip, You can do to this link and save the file with extension (.ipynb) to download it:
https://raw.githubusercontent.com/Esri/arcgis-python-api/dev/samples/03_org_administrators/clone_por...
The download the samples button is not for downloading the particular sample.
by Anonymous User
Not applicable
Philip, we have fixed this error. It would be a while before the site is updated, meanwhile, you can check out the updated sample on github arcgis-python-api/clone_portal_users_groups_and_content.ipynb at dev · Esri/arcgis-python-api · GitH...
PhilipHughes
Thank you
Any chance of getting the samples to download, says 404 error page not found
RohitSingh2
PhilipHughes
Thank you,  got the script,  now running, next problem is
when copying item
           target_item = target.content.add(item_properties, data_file, thumbnail_file,
                                             metadata_file, source_item.owner, folder_name)
Getting occasional error
HTTP error 413: Request Entity Too Large
Is this fixed or is there a constant that can be set.
PhilipHughes
Also getting an error copying item
invalid json  in 'text' parameter
RohitSingh2
What's the json being passed in the text parameter. You can check its validity using the tool at https://jsonformatter.curiousconcept.com/
PhilipHughes
This is the problem,  I am trying to run one of the ESRI samples that copies from one portal to another.  I will have to try and modify code to see if I can dump the data.
