Hello, is there any way to load specified json, depending on actual variable value ? :)
1174
06-04-2017 01:31 PM
JędrekMarkowski
Arcgis JS  I need help with refreshing the map, when the variable changes and the other json file is loaded
Tags (1)
MirHashmi
What is the layer type in your map please. For example, ArcGISDynamicMapServiceLayer.
RobertScheitlin__GISP
Jędrek,
  Sure you would use esriRequest to get the json file and then use Dojo JSON class to parse the result as a true json object.
