Attribute Selections in Pro using 'timestamp' Issue
2882
8
06-01-2017 04:50 AM
LarryGaudieri1
After a skim of online documentation for date & time queries (Time Expressions in Pro) I am confused. I cannot select a date range using Select Layer by Attribute and the clause function. It offers a date-picker or I can scroll to a specific timestamp but when the expression is complete (and looks valid anyhow) it continually reports an error with the expression. Am I missing something?
AndrewHargreaves2
I have this issue too - and am frustrated.
arcgis pro 2.2‌
David Watkins
MichaelVolz
Esteemed Contributor
Can you supply some screenshots of what your query looks like?
What version of Pro are you using?
DeenaBowman
Hello, I'm having the same issue.  I'm using Pro 2.2.4, and the data are an ArcGIS Online hosted feature layerSelect by AttributeSelect by Attribute - SQL
MichaelVolz
I just tested Pro 2.2.4 with a similar date query to your screenshot and it successfully executed the query.  I did this test against both a file gdb and Oracle 12c SDE database.
What is the source of your data (e.g.file gdb, enterprise SDE database, shapefile, other)?
Did you create the data yourself or import it from another source?
DeenaBowman
The data are published as an ArcGIS Online hosted layer.  I've tested with other feature layers published to AGO (by me and others) with the same issue.  I'm not having any issues with  file-gdbms, enterprise SDE or shapefiles.
MichaelVolz
Thanks for the additional information.  I think the key is the data is an AGOL hosted layer as this tool also fails for me in this scenario at Pro 2.2.4.
Maybe the title of this post needs to be modified to reflect the problem is narrower and based on an AGOL hosted feature layer source.
DeenaBowman
Hi Michael, I just stumbled onto this post.  I will create a new posting to reflect the AGOL component.  Thanks for confirming!
MichaelVolz
If this is an important workflow feature for you in Pro, I would start a technical support incident with ESRI.
