Access GeoEvent Server via web server
1556
05-31-2017 12:04 PM
DanHuber
Looking for guidance on how to configure GeoEvent server to work through a web server similar to using a Web Adaptor.   Has anyone here set that up?  I have used IIS Application Request Routing (ARR) for other web services hosted on non-standard ports, but wanted to see if there was a tried and true method for routing traffic to port 6143.    Our goal is to be able to access the Web Socket streaming services via a public facing URL.
Dan
EmmaPaz2
Hi Dan, I’m coming across the same need—looking into what needs to be done w UrlRewrite and/or ARR. Were you able to find a way to get this done? Any advice you have would be most appreciated.
JohnLucotch2
@DanHuber  You ever get to this work?
Huber_Daniel_C
Sorry - I never did.   And I haven't had a need to work with GeoEvent server since that time.
