Internal Web Map Won't Load
931
05-30-2017 01:04 PM
BrianO_keefe
Honored Contributor
I have an Internal ONLY Map that is our Engineering Atlas. It works just fine. I recently upgraded my WAB. I just made some minor changes...
Removed a Widget.
Set the Map Extent to equal whatever was set on the AGOL side.
And that is all.
I downloaded from the WAB and uploaded to our internal server. I renamed the old map to "backup_NAME" and replaced the downloaded copy under the old NAME.
I'm getting a White Screen of death.
Here is my error message...
I made sure to update the proxy.config to point to the DotNet proxy that we have... but still... White Screen.
SO... I changed the URL for the updated on to OLDNAME+map so I can have them running side by side. Nothing I do makes the white screen go away.
Here is EngAtlas working fine:
Here is EngAtlasMap NOT working:
Same map, just from updated WAB.
Any ideas?
SumitZ
This seems to be an issue related to proxy configuration, can you please configure your basemap in the proxy and check.
BrianO_keefe
Honored Contributor
What does that mean? What does "configure your basemap in the proxy" mean? I'm happy to do this, but I don't understand the statement.
DavidColey
MVP Frequent Contributor
Hi Brian, can you provide a little more detail on your sharing setup?  Is the webmap shared organizaion-wide only? Is the app registered with AGOL?  Are you looking to bypass the IdentityManager?
