Javascript API 4.3 unique rendering problem
1496
05-15-2017 03:57 PM
Yunpiao_WhitneyBai1
I'm trying to implement a function that allows to click a polygon to change its rendering. Here is my code.
this.view.on("click", function(evt){
   var point = {
      x:evt.x,
      y:evt.y
   this.view.hitTest(point).then(function(response){
      var graphic = response.results[0].graphic;
      var id= graphic.attributes.SITE_ID; // get the unique id for special rendering
      var lyr = graphic.layer;
      var render = new Renderer({
         field: "SITE_ID",
         defaultSymbol: lyr.renderer.symbol || lyr.renderer.defaultSymbol,
         uniquevalueInfos:[{
            value: id,
            symbol: new SimpleFillSymbol({
               color: [ 51,51, 204, 0.9 ],
               style: "solid",
               outline: {
                  color: "white",
                  width: 1
      lyr.renderer=render;
}.bind(this));
The code runs fine without any error happen, and I also get the legend changed, but the rendering of that polygon does not change at all.  Does anyone have the same issue?
RobertScheitlin__GISP
Yunpaio,
   So I assume you have seen this sample, since your code looks like it was based on this:
Access features with click events | ArcGIS API for JavaScript 4.3
I have not had your issue. Can you share you complete code for inspection?
KristianEkenes
It also looks like you're calling `new Renderer()` when it should be `new UniqueValueRenderer()`
Yunpiao_WhitneyBai1
Robert and Kristian,
Thank you both for the reply. I've found the problem, which is pretty dumb. It is because I did not capitalize 'V' for 'uniquevalueInfo' .
Again, thanks for the answer.
