Toolbar's not showing completely
8301
16
05-11-2017 06:24 AM
deleted-user-amp86F9KgPL3
I just moved to 10.5 and having some crazy crashing going on. The one thing I noticed is that toolbar's and things are rendering weird. Toolbar's not showing completely and other things getting cut off. See attached photos. I am not sure if this is related or separate fires I need to address to get the software stable. Any help would be appreciated.
JayantaPoddar
https://community.esri.com/docs/DOC-2121?sr=search&searchId=a0edeb16-647d-4fae-a341-ad4ddc5f52b0&sea...‌ might help.
Also ensure that the video card driver is updated. Toggle the screen resolution of the machine to see if the issue persists.
Think Location
We updated the display adapter and also checked the resolutions settings and it persists with any resolution setting.
DanPatterson_Retired
try repairing your installation if resetting your application doesn't work
I should have mentioned me have completed an complete uninstall and re installation after updating the drivers. There was no change in rendering after the re-installation of ArcMap.
And you check to make sure your machine will support 10.5 on the installation page?  perhaps it is the machine if a repair and profile reset doesn't work
System requirements .... there is a link in the help to do the testing
We just purchased new machines with benchmarks well above the ESRI requirements. That half the problem that they are new machines running on a strict IT measures and things are still a little buggy, but this seems to be an isolated issue.
AbdullahAnter
Honored Contributor
What happens if you check on Large Icons ?
Well all the others seemed to stay normal but that geocoding toolbar just doesn't like anything.
Oh!  Now I get it... that is a windows 10 and 10.5 thing.... yes... no fix offhand, it happened a while ago during one of the windows updates.  I simply switched over to PRO when it bugged me.  You can change the size of the icons and the fonts, but not the dialogs.  I was going to switch over to another graphics driver since I had two, but it wasn't worth the while.  I am surprised more people haven't complained, so I suspect then aren't on Windows 10 and/or 10.5 yet
