Toolbar's not showing completely
12833
16
05-11-2017 06:24 AM
deleted-user-amp86F9KgPL3
I just moved to 10.5 and having some crazy crashing going on. The one thing I noticed is that toolbar's and things are rendering weird. Toolbar's not showing completely and other things getting cut off. See attached photos. I am not sure if this is related or separate fires I need to address to get the software stable. Any help would be appreciated.
It is a pain... i'm running Win 10 and 10.5, but yes this has gotten me to use pro more as well. I cannot stand when something does't work and look right.
DanPatterson_Retired
Hold up!!! found something.  It was after the last update for me
Then set icons back to original size if you changed them
I haven't checked everything but this is better
Tested on a Surface book with default screen resolution 3000 x 2000
Found out fixing notebook++ which was having the teeny-tinies as well.  Fonts stayed the same but icon scrunchies seem gone.  The figure doesn't do it justice, but if you get the flakies on other applications experiencing this, then give this procedure a shot.
Interesting.... mine isn't showing that override option...?
V_StuartFoote
Requires Windows 10 update to the "Creators"  update, i.e. version 1703
Run WinVer.exe at the command prompt, or use Windows + i to open System -> Settings -> About entry will show 1703 if update has occured (1511 or 1607)
Ahh, yes I am on 1607... ill be on the look out for the 1703
you can get it now... it is dribbling out to all machines, but you can update at your convenience
With our IT in control of the "Windows Update Red Nuclear Button" I will have to wait on this.
