arcgis custom places loaded from file or db
1748
6
05-11-2017 12:56 AM
AndTom
Hello since Google maps can load custom places from .xml file, what about Arcgis, I found that they have example, but its saved in .json format, while i retrieved their example .json and put on my local server seems it can't load, so how to load custom places using Arcgis? Example: https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=fl_featureCollection
FC_Basson
Did you validate the JSON to check it is correct?  And is you Web Server configured to serve JSON MIME types?
AndTom
No, how to configure it?
FC_Basson
Well, what what web server are you running?  You could probably find the procedure for setting the allowed MIME types through an online search.  I'm not saying that is definitely the issue here, so maybe you can show some code?
AndTom
My server is XAMPP based on windows for local server testing.
AndTom
Well enabled:
application/vnd.geo+json
application/geo+json
what to do next?
AndTom
Or at least where i could find in detail explained how to set up custom places?
