Changing the schema and adding old data back in
1278
05-09-2017 10:26 AM
DougBrowning
MVP Esteemed Contributor
In the past when changing the schema I ....
Downloaded a copy of the data
Published the new form
Used ArcRest to add the data back in
But now I am getting this error from ArcRest.  Guessing its a schema issue
So I instead did a Create Local Copy for editing
Ran the Append tool
Checked back in.
This works great EXCEPT I lose the photo attachments.
Has anyone come up with a good workflow for this?  ArcPro maybe?
Any ideas are welcome.  Hopefully Survey123 will handle this in the future.
JohnathanHasthorpe
Hi Doug - I'm not sure what schema changes you are making. But would the following be a suitable workflow?: https://community.esri.com/groups/survey123/blog/2017/02/01/updating-field-types-in-existing-survey1...
DougBrowning
I am adding some new fields and taking some away so not sure this would help.  I will look at it though.  Thanks
DougBrowning
Anyone know how to add photos back into a Hosted Feature Service at all?
