Automated scripting - what's required?
2164
05-09-2017 06:05 AM
AndrewHargreaves
Hello
I'm attempting to write a script that I hope can be ran every 15mins using Microsoft Task Scheduler. Please can someone tell me: Do I require ArcGIS Pro and/or Portal on that machine - pretty certain I don't but just checking.
Tags (1)
JimCousins
What does the script do? Does it reference any of the ESRI object library?
Regards,
Jim
AndrewHargreaves
Please see my other post outlining what I need - I was hoping to do it all via Python API. I'm struggling to understand how to deploy the script I have (nearly) working on my local machine -which has both ArcGIS Desktop and Pro on it - onto a server that has no Esri products.
KaushikMysorekar
Hi Andrew,
IF your script imports the arcpy module for required functionality then you would need to have either Desktop/Pro, Engine or Server installed on your production server for your scripts to work.
IF you are using the ArcGIS API for Python then here are the deployment options: Install and set up | ArcGIS for Developers
