Bernardo,
You are printing before the graphic is drawn. Here is your code updated to wait for the graphic to draw before printing:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<meta name="description" content="[Get started with graphics - 4.3]">
ArcGIS API for JavaScript, https://js.arcgis.com
For more information about the get-started-graphics sample, read the original sample description at developers.arcgis.com.
https://developers.arcgis.com/javascript/latest/get-started-graphics/index.html
<title>Get started with graphics - 4.3</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<script src="https://js.arcgis.com/4.3/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"dojo/promise/Promise",
"esri/tasks/PrintTask",
"esri/tasks/support/PrintTemplate",
"esri/tasks/support/PrintParameters",
"esri/layers/GraphicsLayer",
"esri/Map",
"esri/views/MapView",
"esri/Graphic",
"esri/geometry/Polygon",
"esri/symbols/SimpleFillSymbol",
"esri/core/watchUtils",
"dojo/domReady!"
], function(Promise,
PrintTask, PrintTemplate, PrintParameters,
GraphicsLayer,
Map, MapView,
Graphic, Polygon,
SimpleFillSymbol, watchUtils
var map = new Map({
basemap: "hybrid"
var view = new MapView({
center: [-80, 35],
container: "viewDiv",
map: map,
zoom: 3
view.then(function(){
var polygon = new Polygon({
rings: [
[-64.78, 32.3],
[-66.07, 18.45],
[-80.21, 25.78],
[-64.78, 32.3]
var fillSymbol = new SimpleFillSymbol({
color: [227, 139, 79, 0.8],
outline: {
color: [255, 255, 255],
width: 1
var polygonGraphic = new Graphic({
geometry: polygon,
symbol: fillSymbol
var layer = new GraphicsLayer({
graphics: [polygonGraphic]
map.layers.add(layer);
view.whenLayerView(layer).then(function(lv){
watchUtils.whenFalseOnce(lv,"updating", function(){
var template = new PrintTemplate({
exportOptions: {
dpi: 300
layout: "a4-portrait"
var params = new PrintParameters({
view: view,
template: template
printTask.execute(params).then(function(s){
console.log("hiiiiii")
alert(s.url)
}, function(error){
console.log(error)
var printTask = new PrintTask({
url: "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%..."
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
