Python for renaming file paths
5538
9
04-28-2017 06:33 AM
KelseyQuinlan
Hello all,
I am fairly new to python and am having issues renaming file paths within a table. I need to replace all of my \ for / within a field. \ is an escape so it is not working. Here is a brief snippet of my code:
arcpy.CalculateField_management(in_table="Assess", field="IMAGELINK", expression="""!IMAGELINK!.replace(r"\","/")""", expression_type="PYTHON_9.3", code_block="")
I know there are easy ways to do this with VB and with field calculator but I am trying to automatic a much bigger table update.
edit: I've tried using \ \ instead and still had no luck.
edit 2: This is ultimately what worked for me, thank you Joshua
expression=r"""!IMAGELINK!.replace("\\","/")"""
Any advice is much appreciated! Thanks
JoshuaBixby
MVP Esteemed Contributor
What about escaping the escape character "\\" .
KelseyQuinlan
Yes, unfortunately " \ \" still bombs the script. not quite sure what I am missing here, I thought that would be the easy solution too.
Thanks for the reply!
JoshuaBixby
What do you mean by "bomb?"  Providing the specific error message is helpful for those trying to help resolve your issue.
KelseyQuinlan
Sure thing,
New Script: arcpy.CalculateField_management(in_table="AssessVP", field="IMAGELINK", expression="""!IMAGELINK!.replace(r"\\","/")""", expression_type="PYTHON_9.3", code_block="")
Error Message: Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 3457, in CalculateField raise e ExecuteError: ERROR 000539: SyntaxError: EOL while scanning string literal (<expression>, line 1) Failed to execute (CalculateField).
DanPatterson_Retired
you are tripping over double quotes...
(r"\\","/") blah blah
try (r'\\', '/') blah blah
a couple of single quotes might go a long way
JoshuaBixby
It isn't uncommon to run into issues with backslashes in strings within strings when passing arguments to geoprocessing tools.  I believe either of the following will work:
# or
expression="""!IMAGELINK!.replace("\\\\","/")"""‍‍‍‍‍‍
KelseyQuinlan
Thank you! That did the trick
I really appreciate everybody's input!
curtvprice
Here's how I would do it.
This avoids having to handle the complex string literals by using os.normpath (which converts all delimiters [including duplicated ones] to \ on Windows), os.sep (which allows you to get at \ without having to specify it with a string literal). Lastly, using an arcpy.da  UpdateCursor instead of Calculate Field avoids the complexity of a code block (and, very fastly [you said this was a big table]).
import os
with arcpy.da.UpdateCursor("Assess", "IMAGELINK") as rows:
    for row in rows:
        row[0] = os.path.normpath(row[0]).replace(os.sep, "/")
        rows.updateRow(row)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JeffJacobson
Have you tried using arcpy.da.UpdateCursor rather than the Calculate Field tool? That's how I would accomplish this task.
