FeatureLayer Geometry is much different than the MapExtent
708
04-26-2017 08:04 AM
ChadGullickson
I am using Angular-esri-map v1.1.9 and Angular 1.4.14 and for some reason when updating the definition expression of the FeatureLayer the geometry that is being used to for the query is way off from the map.extent. I dug through the library a bit and don't think its a angular-esri-map bug as the extent on there is correct, I can't seem to find where the javascript api builds that query and why the geometry would be off from what map extent is being shown. Anyone experience this or any help on this issue? Capture2 is the map extent from esri-map and Capture1 is what is being sent in the query when updating the definition expression of the featurelayer
